Garden Lights, followup question...
16 Aug 2004
Has anyone seen or used these before, just stumbled upon the site:
http://www.tlc-direct.co.uk/Main_In...arden_and_Lantern_Index/EasySwitch/index.html
May make life even simplier as I wouldn't have to make up any special circuit from RCD to Switch to Socket to Transformer. I could just have a transmitter switch and a on/off receiver in the garage feeding a plug socket. This would reduce general wiring and also enable me to look smug with a keyring transmitter. Are there any other offerings out there that are as competitive?
Thanks in advance..
seems expensive way of garden lighting, and as i previously mentioned why not have a pir to switch lights on /off (much easier)
also you will have the on going cost of batteries, more wiring, yes i know its radio, but you still have to give it a mains supply
taken from tlc blurb "Then wire an ESR-1 receiver adjacent to a mains power source along
with the appliance to be switched - it’s that easy."
