Garden Wall
12 Jul 2008
Wiltshire
My fence at the back of my garden is slightly higher than the level of my lawn. Theres basically a small slope of earth to bridge the gap.
I'm thinking of building a brick wall only 4-5 courses high to level the gap off and make a flower bed.
My plan is dig the foundations and fill with concete, then bulid up a single skin 4-5 bricks high, 10m long. Will the wall be stable as a single skin, do i need to flaunch the first layer or anything else i need to do?
Thanks in advance.
I'd incorporate 'pillar' type constructions every 1.5 meters or so - Basically a single skin of bricks leading to a pilar (1.5 bricks by 1.5 bricks) leading to the next single skin and then another pillar construction another 1.5 meters along the length.
No need for pillars on a wall that high. I would ensure frost resistant bricks are used, though, and think abut drainage behind it (weep holes will do)
for a wall this small do i still need a good 150mm of bricks below ground level?
Another question, would this type of wall be ok in F1 bricks or would F2 be better?
Any F rating will be fine.
No need for brickwork below ground just have the footing low enough for aesthetic reasons so you don't see it.
1 more question. The footings, is cement best, or for this height could I use some compacted type 1?
no you definately need a concrete footing, 5 inches thick will do and whatever your spade is wide.
So just to clarify, the wall will be 9m long 4/5 courses high. No pillars required?
