Garden wiring - I'm confused.....
Sadly, all this kind of nastiness does is reinforce the general opinion that all electricians, plumbers and other tradesmen are crooks.
Some crooks may claim to be electricians, plumbers or other tradesmens in order to rip of customers.
My landlord just had a lot of work done on the property by a well-known local electrical contractor - they left lights not working, bare wires, sockets not properly installed and a load of other faults that I had to correct.
Some tenants can be loosely described as crooks, as can some landlords. Sometimes they don't pay the contractors they employ so the contractors stop work in mid project. Normally they leave the place as safe as is possible in the circumstances.
Some landlords have to spend a lot of money repairing / making safe the house after tenants have been doing DIY.
Even simple things like routing cable to storage heaters was bodged - rather than using the little 'P' clips Dimplex provide the guys tacked the leads to the skirting boards with cable clips.
You mean the P clips that fall out of the wall under the weight of the cable.
P clips? For the flex to a storage heater? Your having a laugh mate. Dimplex provide a couple to keep the flex of the floor under the heater - They don't expect you to use them to route the cable to the isolator (which should not be any further than it needs to be).
It seems you lack any kind of electrical knowledge, and the installation you describe is a complete bodge and actually dangerous with your "spiked earth on the armour".
There are some tradesman out there who may wish to rip people off, but the majority do a good honest days work. It is often us tradesman that have to put up with fools like you, and have to correct your mistakes.
There are many trolls around the forums, I am not one. Yes, I may have aimed some abuse at you, but hey, I guess the truth hurts?
Deleting your posts because you realise what you have done and said is wrong only confirms this. We did start off trying to help you constructively, but you chose to ignore this.
I've reported the use of the word pr**k to the moderators - it rather confirms my feelings that these forums, rather than being a source of useful advice, are the province of mindless trolls.
Actually, while there are one or two people who have a tendency towards that, on the whole this section of the board is inhabited by some knowledgable and helpful electricians (I'm not an electrician BTW). The advice they have given you is correct, but you give the impression that you have no intention of taking any notice of it. That happens quite often, for some reasons people seem to think that all there is to electrickery is connecting a few wires up and if it doesn't blow the fuse then it must be OK :roll:
J3. I can do what I did - put the wiring in myself (total cost for parts under £60) but because it might be deemed to be an 'installation' I then have to get it documented for Part P compliance at a cost of around £150.
Unfortunately you can't do that - not for £150 anyway.
An electrician cannot certify someone else's work - the only way for them to do your paperwork would be for them to cliam to have done the work themselves in which case they could self certify through their scheme (assuming they are a member of an approved scheme). For the work you've described, no-one is going to put their name to it - sorry.
You can go the Building Control route. You need to notify your Local Authority Building Control dept (LABC) before starting work and pay their fees. When you've done the work, they will inspect it and (assuming it's OK) issue a completion certificate. it seems my LABC are among the cheaper, they charge £150 for minor electrical works if you are in a position to provide the correct test results, or £225 otherwise (which would be the case for you).
But, for the work you describe, it would not pass inspection or testing.
Sadly, all this kind of nastiness does is reinforce the general opinion that all electricians, plumbers and other tradesmen are crooks. My landlord just had a lot of work done on the property by a well-known local electrical contractor - they left lights not working, bare wires, sockets not properly installed and a load of other faults that I had to correct.
Bear in mind that your landlord sounds like the sort that give the rest of us a bad reputation - we aren't all like Rigsby ! Probably went with the cheapest bodger he could find. Doesn't mean all tradesmen are crooks. But, that's not an excuse for you to start doing your own thing - you should have reported the problems to your landlord, and if they weren't fixed, reported it to ... hmm, not sure, who do you report dangerous electrical work to ? I think any of the electricians here would rather see the sort of cowboy you appear to have been subjected to dealt with.
If I found a tenant had been interfering with the electrics, they'd be getting a section 21 notice (be out in 2 months, no reason needed). However, there would never ever be a need - assuming that the tenant actually reported any faults.
Through my work, I come across a variety of trades on site - they "vary in ability" somewhat. Some I like working with, they understand what I need* etc. Others are definitely in the "wouldn't want to work with them again" category.
* When installing networks, it's not uncommon for the electricians to pull in the cables which I then terminate - saves two lots of pulling work and they can "lid up" the dado trunking in one go.
