The issue is the SWA feeding the shed...
I thought that was ok now? What do I need to do?
The SWA feeding the shed is OK as a choice of cable, but feeding it from your ring main is bad practice and could cause you problems. I would recommend extending the circuit back to the consumer unit and put it on a dedicated RCD or an RCBO in the consumer unit (if room to fit another). The rating of the RCD/RCBO should not exceed 16A.
