Garden wooden gate leaning from top
29 Jan 2008
Berkshire
Hi
Our garden gate which is circa 8 years old is now leaning towards the lock side from the top, it’s obvious that the gate fence post is bowed from the top so I’m after a short term solution where I can at least shut and lock it before summer and then attack the post to fix the issue.
Am I right in assuming with t hinges I can either add a shim on the bottom hinge which is screwed into the post side, or somehow adjust the hinge at the top on the gate side?
Some pics below to show the problem.
I don't find your photo very clear, but you say you have a leaning post.
If you fix a horizontal across the tops of the two posts, you can brace them so they don't lean together or apart.
Not really, the only way to adjust T hinges, is by moving the fixing screws. Easier to simply adjust the staple, the socket into which the bolt goes.
probably all the wet weather has caused the wood to swell, the top moves more than the bottom as the bottom of the posts don't move - classic sign the gate won't close at the top
That bottom diagonal brace would have been better going the same way as the top diagonal.
then when the summer comes the gap will look too wide - it surprising how much they move, an inch easy between bone dry and soaked for weeks
Yes, I have a similar problem, and have reluctantly decided that I will reconfigure the gate so it closes against the outer face of the post.
