Gardtec control panel
15 May 2009
Antrim
hi guys - need some advice on a gardtec system.
The keypad had recently developed a fault on the display - cannot see any characters on the lcd. Last week the alarm started sounding. I had to disconnect the sounder to get it stopped.
Now, the control panel is a gardetec 800 series. I intend to replace the RKP with a matching device - have found the item on ebay.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEBIDX:IT&item=230342174618
Are there any compatibility issues ? This should be a matter of hooking up the new RKP, resetting to factory defaults and reprogramming the zones etc - right ?
OK, i have set the jumper to identify the device and hooked up. All appers to be good...except...
when I try to set the system, or test, it accepts the code, asks "do you want to set the system", then just returns to the <<< UNSET >>>
My guess is something needs reset, but what ?
Have you tried powering down mains and battery , wait for a few seconds , then power-up again , see if the keypad is recognised.
