Hi, I hope someone here can help me asap!
I have a Gardtec 816 which has been fine for years apart from the battery has gone - I just got back from holiday to find we have had a powercut and the alarm has sounded (no problem when its happened before)
This time the sounders have not/will not reset. The internal sound was on full tilt when I got in, alarm has unset no problem, everything else seems fine, I can use the system, set and unset but the bell + & - outputs are on 13v all the time and the internal sounder only has 2 wires so it can't be another connection somewhere. I think the - should normally be O/C
I've replaced the battery but the sounders trigger as soon as I reconnect (alarm panel still says unset with mastercode)
I can take the cover back off and do a factory reset, but I remember what a mare it was to program when we installed it.
I also cant for the life of me find the engineer code, but I do have the install manual.
I know there is a SAB SCB mode thing, coud it be that the setting has been lost, if thats the case I can reset the passwords and change the setting I guess?
Anyone got any suggestions please!?!
Lee
Lee
