When i did my part P it was 150mm from gas pipe to any electrical point of connection e.g consumer unit,junction box,socket outlet,etc
and 25mm from any cables.
The main point being is that it should be, not must be!.
As far as water carrying pipes there is no set distance other than you shouldn't have cables touching or run alongside pipes which may get hot.
If gas pipes are buried in walls and protected then the distance is not specified.
