Hi all, im not sure if im way off the mark here as im the end customer and not a plumber etc but let me explain.
four months ago i replaced an ageing central heating system ie back boiler and immersion heater for a Baxi Combi Boiler Duo Tec which now sits nicely in my loft.
I was under the impression that this would help reduce my gas bills as well as do my bit for the environment.
It was fitted in November 06 which conviniently is when one of my quarter starts for my gas bill, hoorha i thought as id have the chance to see the savings on the next bill.
So when i got my bill through at the end of Feb for the quarter Nov - Jan it was an estimated £200 on my previous old system for the quarter. So i called the bas board and gave them the correct meter reading from the gas box outside and they then sent me a correct reading bill.
Imagine my shock when my gas bill was £40 more for the quarter using my new system rather than the older back boiler and immersion?
Im now confused as i was under the impression this surely should be lower?
My gas usage hadnt changed at all as i keep the same timings as i had on the old system so i cant work this out.
I know i should see some savings in the electric bills as the immersion isnt heating the water but surely that shouldnt then mean an extra £40 a month to heat water?
Is this expected or should i be seeing some savings? Can someone please explain?
Thanks.
Thanks.
