    Dismiss Notice
Gas Boiler Flue.
Discussion in 'Plumbing and Central Heating' started by spinley, 26 Jun 2020.
  1. spinley
    spinley
    28 Oct 2018
    4
    Thanks Received:
    Country:
    Had new gas boiler fitted last year, wall hung with outside wall flue all in same place as previous boiler,but more powerful. Have noticed steam from flue blows onto one side of house wall due to the strong west winds i get here, this is causing the paint on wall to bubble off and make plaster render damp. Could i fix thin metal sheet around the sides of the wire basket which covers the flue leaving the front open to direct the steam away from the wall ?.Many thanks for any advice.
  2. lightning
    lightning
    14 Jul 2007
    1,972
    Thanks Received:
    421
    Cambridgeshire
    Country:
    Get the installer back and explain what’s happening
  3. Sponsored Links
  4. dal5band
    dal5band
    3 Mar 2005
    682
    Thanks Received:
    36
    Surrey
    Country:
    On some flue outlets you can direct the flue Left,Right, Up, Down or Straight.. You take the end piece off and twist and put it back on to redirect the flue. This may help if you point the flue away fromthe trouble area.
  5. muggles
    muggles
    28 Oct 2005
    11,633
    Thanks Received:
    2,420
    Daventry
    Country:
    Post a few photos to show the problem
  6. Sponsored Links
Loading...
Share This Page
