gas combi service
1 Oct 2008
Lincolnshire
I have just booked a service on my Vokera Compact 25He and I would like to know what to expect, ie how long does it take, how much of the boiler should he strip? Etc
It's costing £46 which I think is good
Ok in that case, what would the ideal service consist of and how much would it cost (ball park figure) I live in Lincolnshire
very unlikely that anyone servicing your boiler will check your inhibitor but you can buy a little kit that you can check the levels yourself.
With your boiler it is a must that the flue venturi is cleaned/replaced or you will get problems, that is not something that you can do yourself, I doubt however that you will get that done for the price you have been quoted, as already advised you will probably get a flue gas analysis carried out like all the big companies do and they call it an annual safety check because if they called it an annual sales pitch they wouldnt get in the door
I seem to have difficulty visualising your model.
But but on a similar model last week ( called Compact high efficiency on the manual but apparently really a Compact "A" ) the condensate pipe under the boiler was completely blocked so cleaning that is essential to prevent similar problems.
Tony
