Would appreciate some independant advice regarding having a replacement gas fire fitted.
The old gas fire c. 1980 has a worn out valve which is now obselete, but otherwise burns well.
Its a wall hung fire and the flue is a breeze block sized , concrete block with flue hole in its centre, built into the breeze block inner wall. (cavity party wall )
Its an almost vertical rise to the outlet on the bungalows roof with is a 1980s Marley Modern Tile using a Gas Ridge Vent tile with a single opening on each side.
So far we have had the following statements -
A single outlet vent is not suitable, it must be an double or extended type,
it must be a metal terminal.
That type of flue is no longer legal and any new fire must have a new flue pipe , which could only be fitted inside the room. ( not what we want )
So as you can see we are somewhat surprised at the varied advice.
