Days before the building inspector comes ive found a problem.
We're knocking down an attached side garage and replacing it with an extension.
The Architect intended for the drains which run from back to front to be moved to go between the extension and side fence (they currently run uner the garage). Problem is ive discovered the incoming gas supply runs there already. SGN are coming monday to cut the gas off. The pipe seems to be steel all the way to the back of the house, where it must become yellow plastic. So the problem is obviously how can we get the waste water out to the front?
SGN have said they cant cut in to the steel pipe, which would have helped if done in the front garden.
I can think of 3 ways but not sure if they are possible. Or cost effective?
1) Use existing drains which run under the proposed extension. (house built about 55 yrs ago).
2) Install new drains where the old ones are. (under proposed extension)
3) See if theres another way of getting the gas in where it can stop at the front of the house. A new connection maybe.
Any ideas would be welcome. I'll attach a drawing to help.
