Just after a bit of advice.
I am replacing a bathroom and the customer wants his old rusty rad replaced for a towel rail.
Its an open vented system which I was going to plug vent pipe and feed pipe in loft and try and change without draining down if poss, if not drain and refill with suitable chemical for boiler/water.
The issue is the customer has had a new boiler put in and checked with them and was told it needed to be carried out by a gas safe registered person.
Is this correct? If so I will get one in.
Cheers
Si.
Cheers
Si.
