Gas safe peeps
Ho ho ho!
tommyplumb! headman! and how many other aliases?
I think a lot of d1ck pulling going on here :wink: :wink:
I think you're right, it's not dick though. Just the same idiot whose been posting gas related queries under different usernames for the last few weeks.
You'd think admin would do something about him wouldn't you?
Ho ho ho!
Not me mate, but it's still an interesting read. If you look back at all my aliases on here they all have the same theme....Sir Richard Puller/DeltaT/Richie Puller............etc etc etc
Granted I was unceremoniously booted out the combustion chamber pot, but that was my own fault............And I may return, one day.
No, this thread has all the markings of Joe 'Wellhard' 90.
Thanks for all the help,much appeciated.
How does the FGA calculate CO2% in POC?, is there a calculation for this?
How would one calculate the O2 in the POC?
How would one calculate the air% in POC?
I understand some saying the analyser calculates all these measurements so why bother with long hand, would it not be better to know how these measurments could be calculated without a FGA?
Is this not what you gas peeps should know?
Just like to further my knowledge.
Thanks again.
Please don't confuse me with other posters on here, thanks.
11.9 x (20.9 - O2)
---------------------------= CO2%
20.9
20.9 x CO2/11.9 = ?....20.9-? = O2% (fuel lean)
O2% x 100
-------------=XS air%
20.9 - O2
Yep.
Yep
Thats good DeltaT. :wink:
Thanks Monoxide but this has just confused the issue even more so.
Maybe you have copied these calcs straight out of a book?
What does the 11.9 represent?,the same applies to the 20.9?
Please explain? as the calcs mean nothing without knowing what the numbers represent.
Anyone else have a take on this (monoxide excluded)
:roll:
:roll:
:roll: :roll: .............no helping some folks , now **** off.
11.9 is the percentage of CO2 in flue gas with zero oxygen in it. You can deduce that from monoxide62's equation:
monoxide62 said:
11.9 x (20.9 - O2)
20.9
Just set O2 to zero. :) :) :)
Some GCE chemistry and physics might help. This is the reaction for the combustion of methane:
CH4 + 2O2 = 2CO2 + 2H2O
So half the O2 goes to make CO2 while the other half goes to make water. Now it's a property of gases that equal numbers of molecules occupy roughly equal volumes, regardless of what the gas is. :o :o :o So, from the equation above, we see that the volume of CO2 in the flue gas will be equal to half the volume of the O2 that was consumed. Air is 20.9% O2 (so now you know where 20.9 comes from. :) :) :)). The rest is mostly nitrogen and other stuff that plays no part in combustion so 79.1% of the air going into a boiler comes straight out unchanged. Now for some maths:
For 100% of air going in, 79.1% emerges unchanged and half the O2, which is 10.45%, comes out as CO2. This would give us:
%CO2 = 100 x 10.45 / (79.1 + 10.45) = 11.7%
You'll notice two things: I ignored the H2O in the flue gas - because that would have given 9.5% CO2 - and 11.7% still isn't quite right. :? :? :? Leaving out the water would be correct for a condensing boiler and maybe gas analysers ignore it anyway. (Somebody out there will soon put me right if they don't!. :oops: :oops: :oops: ) The other thing I did was to start with pure methane, which natural gas isn't. It contains traces of other gases, notably ethane which gives more CO2 per unit of O2 than does methane. I'm not going into the fine details of that calculation; you can do it yourself. Let's just stick with the final figure of 11.9% CO2 that monoxide62 gave us.  8)  8)  8)
Having measured the actual percentage CO2, you can derive the percentage O2 by rearranging the equation (GCE maths), which monoxide62 has done for you here:
I'm afraid ! can't quite make sense of the last equation for percentage air. Shouldn't it be:
O2% x 100
------------- = XS air%
20.9
or am I missing something. :? :? :?
Dazzling stuff there Space cat...now forget this cr*p and get over to GD and see if my answer was right on that faster than light thread. :wink:
There is a slight floor in that equation , what if POC were fuel rich? hence the reason i added in brackets (fuel lean) , CO2% can be taken from either side of stoich bell chart , this mathmatical equation is only correct if CO2 is derived from right hand side of bell chart (fuel lean) , this is the reason CO2% alone should not be used when dealing with combustion analysis.
O2% x 100
20.9
Your missing something. :mrgreen:
5% O2 x 100
-------------------------------= 31.4% XS air
20.9 - 5%
This may help. :wink:
Products of combustion leaving the appliance with sufficient O2 supplied (per 1 M3 nat gas.)
CO2 = 1.058
Water vapour = 2.019
Nitrogen in gas = 0.027
Nitrogen in air = 7.750
Total............= 10.84 m3
Remember , one cubic meter of methane requires 2 cubic metres of O2 (aprox 11 M3 of air).
