Hi
I had a Gas Safe engineer visit as we are having a new boiler installed.
The current gas supply is 15mm but the new boiler requires a 22mm supply.
I was advised that we need to run a new 22mm supply from the meter and that it will be done in steel.
I should have asked at the time but perhaps someone could give me their advice on here, does it need to be steel, or is it common practice to have copper supply the gas from the meter to the boiler?
The route will go from the garage where the meter is situated, up and under a bedroom that is over the garage, under the floorboards of the bedroom until its on top of the kitchen, then down the kitchen wall to the boiler. None of the route will be external to the house, nor will any be buried in the walls or in any concrete flooring.
Thanks in advance
Thanks in advance
