Any advise on the following
Just had a new boiler fitted, all works well
The fitters advised the gas supply to the meter is lower then expected, called out the Grid, they agreed there may be a small blockage and started to dig up the street and drive, unable to clear or find the blockage the holes were filled in, advised that the pressure is slightly lower then expected but ok
The question what effect would low gas pressure have on the boiler (no other appliance works from the gas supply only the boiler)
What should the pressure be and what would be acceptable
