Gas supply to Hob
1 Jun 2010
Kent
Hi
I'm considering having my electric hob replaced with a gas one.
My kitchen is L shaped with the boiler on one side and the hob on the other, it also has a concrete floor. I'm wondering if I get someone out to do the job will they have to remove the kichen units or is it acceptable to lay the gas pipe on the floor behind the plinths.
I'll put up with the electric one rather than have the kitchen ripped out.
Its not good practice to just lay pipes on the floor.Is it not possibe to fit a batten to the undersde of the cupboards so you could then clip the pipes off the floor?
I'm sure something like that could be done, as long as all the cupboards don't need to be taken out, thanks.
remember that your extractor may also need raising for safe clearance 760mm from burner to exctractor iirc. why not save the expense of running new gas and invest instead in a nice induction hob. even better performance than gas and cleaner.
Thanks for that, I certainly will give that some thought.
