Help, please help,
how do you make a decent joint when joining two copper pipes with brass compression joints using olives
I have old 3/4 copper but the chap at the merchant gave me special big/fatter olives to use with the brass compression joint as it needs to join plastic on the other side.
Everything leaks, drip drip, drip
the plumbing shop says, hand tight and then just nip it. The plumbers that were putting in my megaflow disagree and tighten these joints with some serious effort and they say you must use a paste stuff on the olives, does this pasty stuff really help?
cheers
Gavin
cheers
Gavin
