- Joined
- 27 Jan 2008
- Messages
- 29,648
- Reaction score
- 3,668
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Clearly an inverter generator, but wonder about electronics friendly I would have expected most generators to be true sine wave are you saying some inverter generators are simulated sine wave?The gen is electronics friendly and variable throttle, which means it is quiet.
I suspect that does depend on fridge/freezer on Falklands I know local farmer used a 3.5 kVA generator without a problem except for sheering when needed the 12 kVA the 3.5 kVA ran his chest freezer OK. I know using a plug in energy meter which measures max power with both my freezer and fridge/freezer they use less than 70W until the auto defrost cuts in when they used 140W the inverter drive does not really produce a inrush current like the old single phase motors.I've a cheap petrol genny. Think it's 2.2kW. It won't run our fridge as the inrush for the motor is too great for the genny.
I would think today most power supplies in electronic equipment use switch mode regulation and have a very large voltage range and the capacitor in the switch mode supply is unlikely to allow any spikes through to any electronics. So it should not matter is generator is slip ring or rotating diode type both should work equally as well.
The regulator method will affect ability to cope with in-rush. With the simple twin wound field windings one in series and one in parallel some generators would overload and others would loose field if over loaded and output would be lost until power was removed. We had both 3.5 and 7 kVA models using single cylinder Lister and twin cylinder Lister the 7 kVA would burn itself out with over load and the 3.5 kVA would lose field yet basic same design.
Most generators are not that basic and have an AVR to control voltage. Biggest cause of generator failure was bearing failure which caused then the rotator to hit the stator. The problem was the direct drive engine was white metal and generator only had bearing one end and that bearing took a lot of hammer as engine bearing wore. Those with layrub couplings worked far better as less hammer on generator bearings.
But this was Falklands and generators ran at least twice a day for at least 8 hours to keep freezer cold. Everyone used chest freezers normal was generator on 10am to 1pm to cool freezer and allow women to do washing, and then again 6pm to 10pm to allow lights to work. Radios were all 12 volt and batteries would be charged from generator.
My friend had generator in a shed and could pull stop from house bed room but had to go to shed to start it. That way he would always check oil before starting. Some farms had auto start generators built 1950's the generator was the starter motor on the Lister ST1. These were only 1.5 kVA but would still run chest freezer although only a small one. I know my friend wanted one of these old units as he could leave the farm for a few days and it would auto start each time the freezer demanded it to. I was quite impressed it would auto start even with a 40W light bulb.
I remember using one in Swan Inlet to run the radio and there was only one light switch for all rooms. So to have enough power for radio (transmitting at 1 kW) we had to remove all but one bulb.
My old fridge/freezer which was not inverter did show a 10A start load, but when checking others used by family found this varied a lot from 4A to 10A so I would guess the lower ones would run OK. I am sure BAS has a clamp on meter with max setting and can test fridge/freezer first.
