Geo Cosy System to Tado - help with wiring
As far as I am aware, items should be supported for 7 years, but I know I could buy new fluorescent lamps just a few years ago, and now no replacement tubes are available.
So clearly if the government wants, they it seems do not need to follow the 7 year rule, and clearly any firm which goes to the wall can't continue support.
I am watching the land line at the moment, my broadband router has so much connected to it, and it would be a nightmare to move everything to a new router, I just hope if I need a new router, its name can be made same as old one so my stuff will continue to work.
But the way it shows Geo Cosy being wired, it looks easy to remove.
I fitted Drayton Wiser, and my brother-in-law was saying how he removed his Wiser and has fitted a better system, not asked him what it is, but I thought Wiser was one of the better systems anyway, so what would be better?
But in summer I thought 17ºC was good, nice to walk into a cool house, now I feel 17ºC is too cold, and want the living room at 21ºC. However 16ºC in the bedroom is ample, so how any system can satisfy me I don't know.
£240 for just the wall controller seems a bit OTT. Radiators can be controlled with Honeywell Home Evohome Electronic TRV heads (available separately). So even more cost. To my mind, this 1794699903556.pngis a problem, a system which needs a 13 amp socket to power it, will also need a UPS system, or it will fail with a power cut. I have same problem with Nest Gen 3, except in the hall where wires from the boiler terminate, it needs a USB outlet to power it.
£240 for just the wall controller seems a bit OTT. Radiators can be controlled with Honeywell Home Evohome Electronic TRV heads (available separately). So even more cost. To my mind, this View attachment 426542is a problem, a system which needs a 13 amp socket to power it, will also need a UPS system, or it will fail with a power cut. I have same problem with Nest Gen 3, except in the hall where wires from the boiler terminate, it needs a USB outlet to power it.
It is pricey but gives total control for each individual room in the house which could result in some real savings on your heating bills.
So does Drayton Wiser, Hive, Tado, etc. But unlike them it has to be in one hit, the rest you can slowly increase control as found required or as you can afford.
Main problem with TRV control is plumbers for years have placed radiators on outside walls, OK I can see the point that under a window no other furniture so it can radiate the heat unrestricted, but it also means mounted against a cold outside wall, so more heat lost through the wall, but also more to the point, the TRV is also against a cold wall, some makes like for example Kasa (TP-link) have sensors which link to the TRV head and can be mounted in an inner wall, and some like Wiser all devices in one room can be grouped, so not measuring wall temperature, and some systems will not accept a "demand for heat" if the main thermostat shows over 22°C, but this is the problem, each make has a plus and minus, and people do not seem to want to talk about problems, they will praise the plus of there system, but not tell about the minus points.
For example most have some form of geo-fencing, but most are in real terms useless as either only work with one phone, or only turn heating back on when your just about to walk through the door.
What I do like with EvoHome is it does not "Need" a phone, it can be all set from the display unit, but very few people have more than one system installed, so getting a report on how they work is hard.
Best place for them. When below windows they will negate any "coldness" from the windows. This used to be more of an issue with single glazing but still exists to some extent with double glazing.
When you look at it, central heating in general is pretty out dated and doesn't offer a great sollution other than it heats your home up and pretty inneficient in the way that it does it. I think the Evo home covers a lot of these bases but is expensive, of course as you say it is all dependant on the placement of your rads as to how efficient and suitable your placement of furniture is.
When you look at it, central heating in general is pretty out dated and doesn't offer a great solution other than it heats your home up and pretty inefficient in the way that it does it.
You are spot on with that, what I am seeing is people having a lets face it thrown in central heating system where not thought was given to sizing etc, or control, replaced with a correctly sized heat pump with good control, and claiming the heat pump is better, but it is only better as it was (we hope) sized correctly, and had the original been set up correct, the heat pump would cost a lot more to run.
In a way I blame the adverts allowed, which allow gross misrepresentation of what a device can do, this Exporting 1.jpg must take top place, nothing remotely smart about it, and guess who it is made by!
95% of the time I am in the room with the IHD it shows green either at zero or some export figure, a meter showing state of charge of the battery would be useful, but showing import and export total waste of time. By time it shows export, it's too late, battery already depleted. But they would not pay for export without a smart meter.
I need another pack of AA cells for my central heating, why don't they make TRV heads which can use rechargeable batteries? In all my central heating uses 22 x AA cells to work, and I still have 4 mechanical TRV heads.
At least when they become discharged the valve fails open.
