The land / environment searches for a property we are purchasing has passed, but points to these considerations. Compressible Ground and Running Sand. The last bit says, "Certain constraints may apply to land uses involving excavation", could this mean issues when it comes to digging foundations, if we want an extension in future?
3.04 Geohazards | Compressible Ground PASS (WITH CONSIDERATIONS)
The British Geological Survey indicates that the property is within 50 metres of an area where there is significant potential for compressibility problems.
CONSIDERATIONS: Do not drain, load or de-water ground near the property without technical advice. There is a possible increase in insurance risk from compressibility due to drought or dewatering unless appropriate foundations are present. There is significant potential for compressibility which might cause subsidence damage when loaded by a building or structure, or
when the groundwater changes. Prior to structural changes and any draining or dewatering of the ground near the property a chartered surveyor will need to be
consulted.
3.05 Geohazards | Running Sand PASS (WITH CONSIDERATIONS)
The British Geological Survey indicates that the property is within 50 metres of an area where there is the possibility for sand to
be fluidised by water and ‘run’, with the potential to remove support from overlying buildings and cause subsidence damage.
CONSIDERATIONS: Normal maintenance to avoid leakage of water-bearing services or water bodies (ponds, swimming pools)
should prevent any problems related to running sands.
Certain constraints may apply to land uses involving excavation or the addition or removal of water.
consulted.
