Getting hold of Plastmo bead
13 Jun 2018
Hiya,
I had to use extreme prejudice to remove a bead from a window and left a bunch of unsightly gouges in it, so - if possible - I'd like to replace it. The bead itself has a time and date stamped in it, as well as "6036717 PLASTMO UK BS7413 2002" which I assume is the model number, manufacturer, and BS standard.
Does anyone know where I can a length of this stuff? I need just over a meter long.
TIA!
Post a picture of the damage, so long as no plastic is missing then it could be just a simple heat repair, scratches can be polished out and larger chips or chunks can be filled and painted
Thanks for the reply, and apologies for the delay getting back; haven't been well :(
I've been in touch with Eurocell (who bought Plastmo) and they're going to see if they still have some stock of it lying around. If not, I'll post some pictures.
Thanks again!
Bigger Jim,
I have the exact same problem! did you have any luck with Eurocell ??
