Hi, i have a house built in the 1990's, and its got an indirect cold water system with a cold water tank in the loft and a hot water cylinder on the 2nd floor.
I am looking to replace the thermostatic mixer in the en-suite on the 1st floor, as mentioned in another topic on this forum you must get the correct valve for the water system you have installed.
I presume I need one that states its suitable for gravity fed systems, is that correct?? Sorry if its a dumb qn
Or are ones which states "Suitable for use with high pressure systems or low pressure systems." ok too??
Also what does pressure balanced refer too?
thanks
thanks
