GJD Dygizone remote light switch override
20 Apr 2005
Gloucestershire
Is there a way to wire in a normal style light switch for each zone to manually override the lights controlled by a GJD dygizone?
The helpline says yes but having a quick look it wouldn't be possible to install a strapper between the unit and the switch so I'm at a loss how this would work?
Thanks that's what I remember from the Sapphire model too but they're telling me it's from the 230v side of things, I can't see how that's possible though?
Just had a look ….it’s showing all lights on in the diagram on the keypad cable ….what happens if you short the 0v to A terminal ?
I haven't yet installed as it might not meet the brief per se so will have to report back on that once the expansion unit arrives
Sorry to resurrect this. 0v to a works bit only in mode 1 (detectors operate lights day and night) presumably as the switch sends a signal to the panel but doesn’t reference light level?
You mentioned previously a diode, will this make a difference in this instance?
