glass front kitchen cabinets
8 Oct 2003
Bristol
anyone offer me any advice on how these glass fronted wall cabinets are fitted...the others hang on brackets but these have no obvious signs of how to fix them
ok...the other wall units have thin chipboard backs and hang on wall brackets which can then be adjusted back and forward and up and down. The glass fronted units have a solid chipboard back the same thickness as the rest of the cabinet but no holes or brackets or any obvious way to hang them.
Don't suppose you can tell me what to do with customfit panels as well can you?
Use metal angle flat brackets fixed onto the back at the top of the unit,then drill thru' it with screw & rawlplug plus colour coded screw cap or mirror screw with chrome cap depending what you want it to look like.Without knowing your layout you can bolt it together with wall unit bolts to the next unit.If you don't want any fittings showing on the front you can get hanging bracket which you put one bracket hook type on to the wall and the same on the unit and hang it on.There are many difference type of fittings from a good hardware shop.
Not sure what you mean regarding customfit panels.
