Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
would i gain any benefits (or indeed any drawbacks) from fitting a second piece of glass (ie double, or secondary glazing) to a picture window 3'6" x 2'6".
Its in a very cold area of the house and I want to try and get it warmer.
I stayed in a Hilton Hotel and they have done exactly what you have mentioned. Rather than replace the original ageing windows, they fitted an additional window 1' to the inside. I thought it might be worth a mention that these inside windows ran on a track so you could still gain access to the originals to air the room.
Secondary glazing used to be a common feature in homes. However as the last point made clear with the Hilton, the window was and needs to be free to move for maintenance and becuase if you try to permanently fix the window it is likely to generate condensation between the two panes of glass. You can still get kits for secondary glazing, if not from the local DIY shops, you should find a glass company that will suppply this.
