I have a gledhill accolade unvented water cylinder.
Outside on the drive where the tundrill discharge pipe exits the house is often damp - no water is dripping past the tundrill but vapour is condensing down the clear plastic pipe from the anti-vacuum value (The end of this pipe sits below the tundrill in the tundrill pipe). The anti-vacuum valve is fitted immediately after the hot water outlet of the cylinder to the taps.
My neighbours identical system is behaving in the same way (damp patch on drive)
Is this considered normal? Does the valve need cleaning (crusty limescale) / replacing or the tank bubble recharging?
Thanks in advance
Simon
Thanks in advance
Simon
