Glow Worm 24CXI Leaking Water.
17 Dec 2008
Lincolnshire
I have a Glow Worm 24CXI Combi that has been leaking water for the last 12 months or so. On Heating its fine, no leaks. The boiler looses no pressure at all. On hot water all is fine when you are running the hot tap, but once you turn the tap off water comes from the underneath of the boiler. As soon as you turn the main cold feed isolation valve on the cold feed off the leaking stops. This is how I have been running baths etc for the last 12 months. Someone has suggested it may be the PRV.
its quite common on the early models for the condensate trap to leak acidic water onto the plate h/exch and cause it to corrode badly and leak. I would be checking this and the plastic saniblock for hairline cracks.
