Glow Worm 35ci Pressure problems
Evening all, I have just replaced the PRV, charged the system to 1 bar, turned on the heating - Water discharge and a pressure of 2.7 bar when I turned the heating off. The pressure then dropped to 0.6 bar. The temperature was reading 65 degrees C.
Is temperature a related issue or has anybody any other reason for the discharge with new valve fitted ? Any thoughts would be gratfully appreciated.
Darren.
Hi folks,
Thanks for your questions and comments, I changed the PRV because it was constantly discharging, I am not clear about the expansion vessel issue, however will investigate further.
Re; Good or bad boiler; up until this point it has done what it said on the tin (installed 2004).
Once again thanks for the dialogue.
Darren.
Darren.
Hi folks,
Darren.
