Glow-Worm Boiler cuts in/out
AJS
25 Feb 2004
Have a glowworm Micron 50FF. Ocassionally the thing shuts down - no heating or hot water. A reset usually cures. When operating OK it often starts the ignition sequence, then within seconds stops. Then a few moments starts again, and so on until eventually it starts and continues. I have checked the air pressure sw and appears OK. I am confused by the thermocouple range stated in the manual 14k - 2.5kOhms it says (is this right?)
Recently it has settled into a pattern whereby it starts to fire up, the ignition fires up the boiler and then just stops. It then goes again a few moments later and once the thing has lit it just stops again. After a few goes at this it stays lit.
Help!
