Glow Worm Central heating [24ci] - F2 error
2 Apr 2007
London
firstly, apologies for seeking help rather than contributing something!
but as you know, without central heating survival is very difficult especially with old aged parents :cry:
GCH system, starts up as expected with green LED (light) & a humming sound, i can hear a tick sound when we turn the hot water taps.
While switching on Heating, the small LCD status panel shows temp, increases upto 18 degree, it waits for a while and shows F2 on LCD and LED turns to red.
BTW, model is 24ci
any help much appreciated
sunil
from your handbook
air fault,pressure switch or no power to fan
Time to get someone in i think
Cheers
tally
That is a fairly unusual fault on your model.
Apart from checking that the flue terminal is not blocked, obstructed or damaged there is probably little that you can do yourself.
Thanks for the replies!
Pressure (is) was 1.2 bar since jan 2005 (i moved in)
Can you guys recommend a good & reliable technician in SE15/SE5 area (who does not rip off me) please?
cheers
sunil
