- Joined
- 24 Jan 2016
- Messages
- 3
- Reaction score
- 0
- Country
Hi, I have a GlowWorm Cx381 condensing boiler and I am getting a F14 fault (the hot water heats up but after a couple of minutes the F14 fault appears, water goes cold, then water heats up again). The British Gas engineer said this was caused by the heat plate being blocked and recommended a power flush of the CH system (as well as replacing the heat plate) as he thought the gunk from the CH system had blocked the plate. I am confused as to why the CH causes an issue with the HW - I appreciate they both pass through the plate but surely they are separate systems? BG have quoted £790 for power flush with seems exorbitant especially if it is not the root cause. Any ideas? Thanks
