Glow worm Energy saver (30 years old ) flue extension?
4 Feb 2009
Yorkshire
Hi Again.
I have a Glowworm Energy saver mounted to an external wall.
On the outside, is a square stainless exhaust with a built in cage and
a flat stainless face.
I currently have a carport above this (about 5 feet) which I am about to have re-covered..
Is there any way I can extend the flue so that it can pass
through the carport roof and exit above it?
I realise it is an old boiler but are there any ways of doing this?
Cheers.
Ian.
The Energy Savers were all fan flued and I doubt whether you'd get any flue for this now. Casting my mind back I don't recall a vertical flue made for it then. They were around 15-20 years ago.
Do you mean a Glow Worm Space Saver? If so the vintage is correct and the answer is definitely no.
If it's a Fuel Saver the answer is the same.
Thank you both for the advice.
Looks like I'll have to treat the underside of the carport then.
Thanks again.
Ian.
