Very good for the money. Versatile flue options. Have serviced a couple and found nice clean traps and sumps after a couple of years, thats a good sign for a cast heat exchanger. All I would say is the 35kw version is quite noisy when in hot water operation so not ideal in/above/under a bedroom. Also being a large cast HE its much less likely to be affected by any system debris like the gianonni HE in most boilers.
