Help I have just moved into a new house that has a Glow-worm Fuel Saver 80 F. the boiler lights up fine and then runs for about 30 – 40 seconds and then shuts down for about 30-40 seconds and continues like this, any ideas?
bab said:could be aps
The Trout Catcher said:Help I have just moved into a new house that has a Glow-worm Fuel Saver 80 F. the boiler lights up fine and then runs for about 30 – 40 seconds and then shuts down for about 30-40 seconds and continues like this, any ideas?
raden said:The Trout Catcher said:Help I have just moved into a new house that has a Glow-worm Fuel Saver 80 F. the boiler lights up fine and then runs for about 30 – 40 seconds and then shuts down for about 30-40 seconds and continues like this, any ideas?
I would be fairly sure that your problem is the fan, which overheats causing a resettable thermal fuse attached to the winding to open and cut out
If this is the case, please acknowledge that this was the problem, then they will know better next time
I have noticed that none of the 'experts' on here have commented on Radens comments.Soggy_weetabix said:[If this is the case, please acknowledge that this was the problem, then they will know better next time
David
raden said:[I would be fairly sure that your problem is the fan, which overheats causing a resettable thermal fuse attached to the winding to open and cut out
