Hello all, I've got a glow worm 18hxi, and the other day i saw that some water was dripping down the side of the case, the whole system was working still. But to be on the safe side, and i turned the whole system off till the morning. Anyways by the morning there was no dripping so turned it all back on and for about 24 hours it was fine again. But after then if started again, so i opened the boiler up to have a look inside. The leaking was coming from a grey pipe, which was connected to this plastic box on the right hand side of the boiler, which i think is something to do with the overflow, because the overflow pipe which goes out side (plastic type) is also connected to this box, also there is a black pipe as well. The water isn't coming out fast or anything its one drop at a time, and isn't gone cause anymore damage because all the pcbs and such are off the bottom of the case. This gray pipe connects to this plastic box and then goes to the big stanleless steel thing (i don't know alot about boilers) the thing which is burning the gas, cos i can see blue flames in it. Yesterday the pipe wasn't dripping it was fine, but this morning i turn the centre heating on left it on for 30 mins or so, then checked the boiler and it had started dripping again. I can's be 100% its the centre heating causing the problem because i didn't check this morning it may of started last night, but it was fine all of Yesterday and at no point in the day did i have the centre heating on. Also where i live its really cold at the moment and lots of snow, and this seamed to of started when the cold kicked in. So if anyone could tell me why its doing this and maybe a fix that would be really helpful?
