Having a few problems with my heating system....
The boiler over temp cut-out keeps popping out. the pump still runs obviously due to the room temperature thermostat still under room temperature. Sometimes the boiler will be fine for a few days and then this happens
This has only really began since I drained the system to remove a radiator while decorating (flushing out & spray painting the radiator also)
There was a lot of air in the system which I have bled but now and again there is a 'hell of a lot' of noise coming from the pump area which is situated in the eaves above the boiler.
Any help would be appreciated
