I have a problem with my boiler it will not give a constant supply to the radiators, once the room temperture reaches 16 deg C the radiators cool even thou the room thermostat is set to 21 degC, Also the hot water only reaches a warm temperture. All the pipe work and radiators reach very hot tempertures initially but this does not continue! Within the control box I have noticed a constant sparking from the circuit board, this occurs on a neighbours identical boiler but only happens when firing up and then stops! Could this be the problem and how much would a new circuit cost? Please can anyone advise?
