Does this sound right to you?
A friend of mine is renovating a property and has just paid several thousand pounds for a Gloworm Combi and multi radiator intstall. He wanted to move his outside tap a few feet, so he shut the water off at the stopcock and then drained outside tap. Approx two buckets of very hot water came out of the tap This is an outside cold tap.
Now I am not an expert, but this doesn't sound right to me, but the guy from Gloworm says it's supposed to do that, drainig back down from the boiler.
They also installed 22mm copper to all the Rads stating that you get more flow than 15mm, but surely the heatloss from the pipe surface area would contra this?
Any thought? Thanks
Any thought? Thanks
