gloworm spacesaver 50 bf mk1, time for a new boiler
17 Nov 2017
Hi guys , i need your expertise please,i think the gas valve has had it on my boiler , iwas checking for a suspected gas leak and have traced it to the main injector for the burner , when the boiler is not fired up but in the on position , there is a small flow of gas just about blows a bubble when soap suds are applied , as it is the main injecter i lit it and it is the equvilent of a small candle flame,if i blow the pilot out the gas flow stops , also if i turn the gas valve to pilot it stops the flow,has the gas valve had it, i doubt i woould get a replacement boiler is working fine otherwise,
thanks for taking the time to look
Rob
Gas valve is readily available but you really shouldnt be messing around with it
after more checking by boiler has abspestos in it. so it needs to go.any advise on how to get this done its a glowworm spacesaver 50 mk 1 cana gas engineer do this or does it need a specialist
thanks
thanks . i have been debating wether to change it for a while and have decided i am going to now
