Hi scooby, My take on this, (and I am not a Glow worm expert BTW) I don't think you are going to have much joy with this one (bar somehow reprogramming the boiler software) and It's pretty obvious why, The two devices (boiler and roomstat ) are not very complimentary due to the way they are designed to work
The trouble is that the boiler is designed around a different type of control system in mind which doesn't include TPI thermostats
Boiler from cold will fire on high gas rate from cold within 15 seconds or so. However subsequent fires sit on low gas for the same amount of time which happens to match the proportional time of the MPRT stat plus 3 seconds so only get a 5 second high gas burn!
Anyone got any ideas or do they all wait this long on subsequent burns?
yes, when there is a demand for heat from cold on its stat interface it will fire and and go on to high rate quickly, there's nothing wrong with the programming there!
Now the subsequent burn
as far as the boiler is concerned if the demand has ended then the room must be up to temp so allowing for a stat hysterisis of a degree and a half eg when there is a further demand for heat then why shift up immediately to high fire when ticking along on low will more efficient,better for the boiler and probably be good enough to satisfy the demand?
looking at the flow temp is irrelevant as depending on the ambient that particular flow temp may be enough, there's nothing really arguably wrong with the programming logic there either as as far as I'm aware glow worm don't promote TPI control and why should they as that particular boiler supports its own compensation controls which are far superior To the TPI stat you have fitted (this is not a dig by the way you have just been unlucky)
To get that system running the way I think you want it to then I think you have 3 choices mate
1)Talk glow worm into coming round and reprogramming the boiler to operate the way you want it....good luck with that!
2)Fit a different boiler that is more friendly to the stat
3)Fit a different stat that is more friendly to the boiler
This could be normal operation, check with S codes just in case and give glowworm a ring.
You might want to try these when you upgrade...
http://www.glow-worm.co.uk/products/controls/climaprosub2-sub-rf/
http://www.glow-worm.co.uk/products/controls/smart-wiring-centre/
http://www.glow-worm.co.uk/products/controls/new-wireless-outdoor-sensor/[/QUOTE]
I think I have to agree with Andy here
or
this would be comparable to the Myson one but better as it will modulate the burner rather than switch it on/off
Matt
