First time poster. We have replaced the pressure release valve, the pressure vessel and the heat exchanger and still experiencing drops on pressure overnight which require a top up to fire the boiler up. No leaks in the system as had thermal imaging survey also no drop of pressure throughout the summer months. Replacement of heat exchanger thinking was a cross over between CH and HW. Still getting drips outside from the prv, cannot fathom why the pressure could get above the point to activate release? Only other symptom is a drip from the condensing waste pipe not sure if connected. Any thoughts as the engineers are running out of ideas and gloworm technical assistance has been limited
