Glowworm 24cxi pipe outside house dripping water
15 Dec 2013
Manchester
I have a Glowworm 24cxi combi condensing boiler, it's about 10 years old, has had its ups and downs but still going.
The last time I had it serviced, I mentioned to the chap that the pressure had gone down, and when I filled it using the filling loop, it had gone down quite quickly again from say 1.5 to 0.7. He said this was nothing to worry about and I should only worry if started flashing red.
I didn't therefore worry too much, but a few months ago I started noticing water appearing at the bottom of my outside wall. At first I thought this was a leak from a neighbour as he said his toilet was leaking, but it turned out to be nowhere near this.
I then noticed that the metal pipe which sticks out of the wall, way down from the funnel which steam comes out of, was dripping water, and sometimes quite a lot of water is coming out and dripping onto the paving outside, so I am trying to figure out if the water I have been seeing is from this and if this is normal, or whether it is either related to the pressure drops, or there is a leak somewhere else which might also be related.
I have someone coming out to it this week, but just want to gather information as I'm wondering if the chap who serviced it last should have been a bit more interested in the pressure drops I mentioned rather than just signing it off as fully functioning? :?
If it only really starts dripping when the central heating is on then its very possible just the expansion vessel needing a look at. What does the pressure read when the heatings hot?
theres a possibility that the valve which allows this overflow to run may need changing also if its been dripping for a while.
Thanks. Have been running the heating, turned on the hot tap to get the pressure to display and it was 0.9 It was 1.0 when I got in today and 1.5 when I filled it yesterday afternoon, so not sure if all the pressure is being lost out of the dripping or something else going on!
Frustratingly, I can't seem to find a picture of what a pressure relief pipe is like anywhere on Google, to compare to the pipe I have. It is a metal pipe which comes out of the wall and bends downwards, is the only way I can describe it?
I will try to take a picture but am away from house at the moment.
Got someone coming on Wednesday.
Thanks for the answers here, I had someone out today to fix it, he replaced the pressure relief valve, pressure reading all as it should be now.
I still have the issue with the water, have posted elsewhere in more detail about this, but what he said was if I had an internal leak, it would be unlikely to find its way through the walls to the outside as in the picture linked to below:
http://postimg.org/image/dvjm8ahfb/
Any thoughts would be appreciated, my neighbour has said it's nothing to do with him, but the plumber today said from what he can see it's 99% certain the source is the neighbour's house and not mine.
I just want to arm myself with as much info as possible before I confront my neighbour for the 4th or 5th time about this (last time he said his toilet was nowhere near the leak, but there is a plastic overflow pipe sticking out of his wall not that far away, which can only fall onto his flat extension roof if it does overflow, and may also be a problem with his roof...
BTW, I asked the bloke who fixed my boiler (from British Gas) whether the pressure relief valve leaking would have led to inhibitor leaking out of the system/becoming diluted.
He said no.
Was this the correct advice do you think?
Apologies for any questions that sound stupid, I am not very handy and need to learn basic things, thanks.
