I've read through existing posts but need some clarity before I go insane!
Pressure overflow was leaking for a few days and so had an engineer come out at the weekend. He has replaced a couple of boiler parts but now the system is losing pressure and needs topping up constantly.
This problem was not there previously but the engineer isolated the boiler to "prove" that the pressure loss was within the system and not the boiler. No signs of leaks (although the ground floor pipes are cast in concrete).
So... the scenario is:
When the CH is on the pressure is maintained
When water is on pressure drops
When boiler is off pressure drops
Question is, what does this mean? If this is a leak then is it on the CH loop or the water loop or both???
All help/(non-abusive) comments appreciated.
