Glowworm Ultimate 120FF not working due to damaged PCB
27 Oct 2009
Surrey
The boiler stopped working earlier today. It is a direct fed system.
I've followed the fault finding flowchart in the manual.
Seemed to suggest the fuse or PCB.
I removed the PCB to find that the solder joint had melted where one side of the fuse housing was attached to the board. I re-soldered this temporarily but don't trust it. Seems to smolder/heat up.
Have now disconnected and will order a new PCB in the morning.
Any thoughts why this happened and if it will reoccur with a new PCB?
Is something else the route cause?
Was due for it's annual service this month so hasn't been neglected ;o)
Mike
P.S. have had to replace the sparklead several times, There seems to be a design fault where the casing causes it to short after a few years use.
Any dry joint (the term for a defectve soldered joint on a pcb) will create heat, due to the increased resistance created by the fractured joint, it is not uncommon to find a 20mm or larger hole burnt through the board, so I suspect a new PCB will be the fix and no worries :wink:
if your service engineer has replaced any suprima pcbs lately he might have some left over electrode lead insulation. A bit of this on your lead where it enters the case should help prevent further failures :wink:
Thanks for your replies guys. Really helped ease my mind.
I removed the fuse and shorted the connection to get temporary operation. I did think about replacing it with a fused cable you can get.
But the thought of the root cause returning gave me too many paranoid thoughts. :roll:
So took the belt and braces approach and replaced the PCB.
A £100 lighter in the wallet but a weight off the mind :D
Thanks again. Mike
