glowworm ultimate 40 ff wont ignite
22 Jan 2008
Manchester
can anyone tell me why my boiler will not ignite you can just here the fan runing and all fuses are ok
APS switch knackered, dirt in the venturis, pipes come off that connect fan to APS, all RGI territory though.
do you have a filling loop or a gauge telling the pressure of the system?
its not a combi no loop for filling up .i have replaced the spark electrode still nothing happened .i left it for a few hours and then tried it again and it firerd up then i switched of and then it would not fire up again
is it sparking at pilot or not,if not it seemss to be aps fault blow dowwn tube and see blow very lightly
no its not got the loop for filling and its not a combi .i have replaced the spark electrode.and it did not work so i left it for a few hours then i tried it again and it firered up .left it to run for a hour and then turned it of and tried to start it agai and it wont fire up again .do you think its the solinode
hi alan there is no spark just fan running and we have cleaned the pilot jet and fitted new electrode
I know an ultimate isnt a combi :rolleyes: thats not what i was getting at, I was trying to ascertain if the boiler was on a sealed system and you may have had a blocked low presssure switch.
But you have nt
blocked pilot light I would say
I WOuld be looking no further than either a blockage in the tubes,faulty aps or fan not fast enough to open aps.I would check the tubes and aps first as it needs that to open to allow ignition sequence to begin
andy, on them the aps is on the side of the control box when you take the bottom drawer off just try removing a tube and blowing down the aps
