Gluing laminate flooring
30 Dec 2008
Bristol
I have some laminate flooring that I want to use on a small bit of wall for a bit of decoration (it looks better than it sounds). It's about 1m2. What would be a good adhesive to use? I was considering Gripfill or PU. It's going onto plywood
I have a couple of different laminates, one has a thin foam on the back, I tried to peel off a small section and it is very well stuck. Can I just glue it straight up as is?
