You are aware there are different colour tones, i find the warm white ones nowadays are very similar to the older halogen lampsI changed the 8 spotlights in our kitchen for LED's. Mrs Mottie hates them and calls them 'kebab shop' lights.![]()
Yeah, I got the bright white ones which I preferred. Should have got the warm white ones. I’m just hoping she'll 'warm' to them. It’s been over a year so far with no luck though!You are aware there are different colour tones, i find the warm white ones nowadays are very similar to the older halogen lamps
the large one did not flash or flicker, the package does not show watts, or Lumen neither does the bulb, but work well, however the cover will not fit over the bulb, the halogen bulb is far smaller and must have cover fitted, the small LED flashed when switched off, and flickered when switched on.
of bulbs which will likely last my life time. Included in that stock are the bulbs given to my parents to get them to move over from tungsten, compact fluorescent lamps, which are to be withdrawn from sale, the move from B22d to E14 and E27 has resulted in few places when I can still use the old bulbs, still use tungsten bulbs to keep my fermenter warm when brewing beer, LED do not work they don't produce enough heat.However the problem is finding which LED lamps don't flash or flicker, there are LED's with smoothing capacitors which don't flicker, and there are LED's with leak resistors which don't flash, but no requirement to put on the packaging which are which.
Yes however the war of the currents was won by George Westinghouse not [URL='https://en.wikipedia.org/wiki/Thomas_Edison']Thomas Edison[/URL] so we have AC supply into the home, and the way bulbs are made they will often simply not work with DC as they use a capacitor as a current limiting device, so any smoothing of the DC has to be after the capacitor so inside the bulb.The problem is finding LED drivers which do not cause the LED to flicker, flash or fail prematurely.
An LED element fed from a battery with a current limiting resistor in series with the element will provide constant light. A regulated and well smoothed DC power supply can be used instead of a battery.
Have you actually tried this (with an LED 'driver'/PSU) and seen it to make a noticeable difference?Axial leaded electrolytic capacitors .... have a much better high frequency response than a radial leaded capacitor of the same value ...
I thing that statement may need some editing?... Changing the output smoothing capacitor from a radial to an axial type can result in much higher spikes and / or high frequency energy coming from the supply.
Changing the output smoothing capacitor from an AXIAL to a RADIAL type can result in much higher spikes and / or high frequency energy coming from the supply.
You're welcome - I only wish that I could notice my own typos/errors as well as I can notice those of othersAnother error by me and spotted by John
I have a fitting in my bathroom that takes very small halogen bulb, ill this mean i have to replace the fitting.
The quartz bulb should not be dimmed, the whole idea is the quartz is so hot the tungsten will not stick to the quartz, running them cold the tungsten coats inside of quartz which can be seen as it goes black. The glass cover over the quartz is to stop white hot quartz landing on the carpet should a bulb fracture when it blows, it is not required when using LED bulbs, however it does charge the look of the lamp without the glass cover.I deliberately stocked up on 60W tungsten G9's as the LED replacements (there are NO equivalents AFAICT) are too big to fit in the fitting, too dim and mostly non-dimmable. If anyone knows of a 10W dimmable G9 LED lamp with the same physical dimensions as a normal halogen one, please let me know.
will fit in the standard glass cover, rated around 2 watt, but using an electronic switch there is a shimmer when switched on, and even with 5 bulbs it needed a load capacitor to stop it flashing, the temporary cure was fit one quartz bulb, however once there are no quartz bulbs clearly that option closes. well I tried them and they do flicker and flash when turned off.Philips master G9 2.3W No flicker apparent on any tested bulb
at the side of the bed is a requirement, together with a switch that works with it. Saying don't use a dimmer then does not really work, I don't use a dimmer, and can get some smart bulbs, but not G9, a hunt for 22019274 G9-69SMD written on the bulbs that work does find results, here for example but one big problem, it says currently unavailable. If you need to find a tradesperson to get your job done, please try our local search below, or if you are doing it yourself you can find suppliers local to you.
