Greetings,
We've started decorating our house and I would appreciate any advice - in case I'm missing anything obvious.
I've started stripping the skirting and architrave using a heat gun, which looks like one layer of white gloss and a pinky layer underneath. It's coming off ok, but to be honest I don't know if it's lead-paint - the house was built around the late 70s. I'm wearing an AB1P2 mask from Wickes and keeping the windows open.
I plan to get the last little bits off using paint stripper and a scourer, but I'll do that all in one go as I'll need to get my pet parrot out of the house for a day or two. It's being stripped back to wood because we quite like the wood - it will be varnished/waxed/whatever.
I know it would probably be easier to remove the architrave and skirting, but the walls are in a decent condition, and I'd like to avoid throwing out perfectly good material.
Should I worry about lead content in a property of that age? Would the above face mask and heat gun/scraper solution be acceptable if there is lead? I don't plan on sanding any of the paint.
Thank you advance.
Thank you advance.
